GoFlight Interface Tool for Prepar3d V3
Downloaded P3d v3 on the 1st day it was available...PMDG has already issued a compatible installer...Naturally I had to try the current version of the GFIT with the NGX. No joy, as It failed to locate the Prepar3d ini file. Do you intend to update the GFIT to support P3d v2 ?
Robert
Robert
Hi Robert,
I will. A work around in the meantime would be to untick the Enable for Prepar3D in the Settings tab and check or set this option manually by using notepad to open the following file(s):
For the NGX: <your flight sim directory>\PMDG\PMDG 737 NGX\737NGX_Options.ini
For the 777: <your flight sim directory>\PMDG\PMDG 777X\777X_Options.ini
and ensure the following exists:
[SDK]
EnableDataBroadcast=1 (if this is set to 0 change it to 1)
You will also have to manually install the GoFlight Interface Module.dll as detailed in the installation instructions of the userguide on this website.
New version of GIT uploaded which now supports v3.
