Basic general
Trying to get the Prop Synch to work, works ok with the Go-flight module set up.
In the GIT, I can select the same Toggle Prop Sync and the light indication but it has no reaction. If I toggle the VC button the indicator comes on, there is only a toggle selection available as far as I can see (same as in GF config) no matter what unit button I define it to, it will not trigger the action.
I can define it in FSUIPC and it works ok as well.
Any suggestions please ?
Trevor
Trevor
Hi Trevor,
Is the prop sync default FSX or an advanced aircraft using lvars, custom events?
Hi Trevor,
The Simconnect SDK had an error in it. It came with the event TOGGLE_PROP_SYNC, however the documentation states its TOGGLE_PROPELLER_SYNC.
I have updated GIT and it now works OK. Wait for the next release, and remove TOGGLE_PROP_SYNC from your configuration.
Glad some of my problems help
Hi Trevor,
This issue is now fixed in 2.0.351.0.
