p3dv3 canot find ini file
Hello
I am having a bit of trouble with the goflight interface tool. my setup is
prepard3 v3
pmdg737 ngx for p3d v2 or v3
GoFlightInterfaceToolP3D_Setup_2_1_18_0
goflight config ver 2.2.5 Biuld 0
I keep getting a window when i start the git saying p3d ini file not found pmdg options file cannot be checked / updated
can you tell me how i can fix this problem please.
thank you very much.
Tim
prepard3 v3
Tim
Hi Tim,
If everything is working apart from the error message, see the last entry in the FAQ: http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
Tim
The ini file it refers too is the PMDG options ini file for the 737/777. It simply checks that the SDK has been enabled. Just untick the P3D box and the check will not be done and the message will go away.
