Small error With GF166 /Default FSX COM1&2 setting
When I use the button to set default COM1&2 with the GF 166's they work ok except that it always sets the left and right displays as "divide_by_decimal" and 100 in the light value box the light display data section.
I have to go through each new aircraft and change the setting to none otherwise 128.30 would be displayed as 1.28. Not sure if it's just a typo in the default setting? All of the default aircraft I tried in P3DV3 didn't need divide_by_decimal
Steve McNitt
It might be there from when it was originally developed for FSX. I'll test against all versions of flight sim and come back to you.
Fixed in 2.1.18.4 that I'm uploading now.
