GIT won't start
I'm having difficulties getting the latest GIT version to run.  My computer crashed and after reset, whenever I double click the icon it does nothing.  I've tried multiple uninstall and re-installs and still does the same thing.  Previous versions will work however they all crash whenever I press the use default button for the MCPPRO.  I'm using P3D 3.1 on windows 10.
    I suspect the config file is corrupt. Rename the directory My Documents\GoFlight Interface Tool to My Documents\GoFlight Interface Tool.old and see if the problem goes away.
  • Hi Steve,  tried your suggestion but GIT still won't open.   Very strange, all was working well a few hours ago.
  • edited January 2016
    There was a bug with the use default button on older versions. Make sure you have the latest version installed, along with a renamed directory as previously advised.
    Hi Steve, I found the issue...I deleted the user/appdata/local/pollypot software folder and it is working again.
  • Great, thanks for letting me know.
