GFIT 2.1.18.3, P3Dv3, SECM crash and G166 COM issue
I have been using v2.1.18.3 GFIT as advised, to correct a crash when attempting to set the MCP using DEFAULT.
I have since purchased a SECM and GF166.
Attempting to set the SECM using the DEFAULT button in GFIT causes a crash in GFIT, similar to the crashes I used to have with 2.1.18.0 & MCP
Second, anytime I use the DEFAULT button from COM for the GF166, the displays appear to be divided by zero.
And lastly, can anyone advise if its possible to alter the default COM function so that switching between COM1/2 set will illuminate the left LED when, for example COM1 is selected, and not lit when COM2 is selected?
Currently I dont have any way of knowing which COM set is currently active on the GF166.
Hi David,
Thanks for pointing out these bugs. They have crept in as part of the X-Plane update. I'm uploading a new version now (2.1.18.4) that fixes all you have mentioned.
