Aircraft Configuration Downloads
Downloaded the aircraft configuration for the Majestic Q400. I believe I followed all the steps correctly and am not sure what I should expect as a result. Should the MCPPRO and EFIS be configured and ready to use? If so then I messed up somewhere.
I have successfully configured lights, batteries and a few other things but now sure whether I still have to configure my MCPPRO and EFIS. Right now the only thing that appears to be functional is the ALT dial on the MCPPRO. If I messed up, any help on how to back out of what I did and try again would also be terrific.
Will keep working on it. Any advice and info is much appreciated.
dave
  • Did you import the config on the MCP PRO and EFIS tab? If yes, quit GIT and restart it.
    I Imported the mjc8q400_GFMCPPRO.xml from the MCPPRO tab and the mjc8q400_GFEFIS.xml file from the EFIS tab.
    Have restarted GFIS several times since I did this a few days ago. So far the only functionality I have noticed is the altitude knob which is working. Will be spending some time this evening exploring the issue.
    Can I somehow undo the import and try again or import again over top of what I have already done?
    thanks
    dave
  • You can import again. Try contacting Slayer here on the forum as he wrote the config.
  • Thanks Steve,
    Now have the heading knob, VS wheel, altitude knob and some buttons working. For the life of me, can't figure out the Course knob however.
    How do I contact an individual member in this forum. Can't see where the members list is. Would like to ask slayer about it.
    Thanks again.
    dave
  • Click this link and then click the Message button: http://www.pollypotsoftware.org.uk/vanillaforums/profile/115/Slayer
