Q400 pro & MCP PRO
Hello all
Seriously out of my depth with this at present, can anyone take pity on me and provide a basic setup for the above, got the q400 files from the downloads area but no lights work, wondered if its because I have the pro version.
I did note that a number of people were working on this, did it prove to be unachievable? If so please let me know, thanks
dave
Cliveparrot - is everything sorted now?
It works thanks, for some reason it doesnt work with the Dash 8 when using FSI Panel, when arming approach it just freezes the Dash in midair with all the warnings going off. The 777 does work with FSI Panel though, thanks for the help on the forum :-)
Checking the FSI Panel you need a registered version of FSUIPC for it to work with the Dash.
I do have a registered version Steve
Thanks very much
Hi Wayne,
You load the xml file into Detective (Bespoke Events), then go to the MCP PRO tab and import the other file that configures your MCP PRO. Make sure you have GFConfig configured to a compatable add-on.
The GoFlight Interface Tool (GIT) is the successor to the GoFlight PMDG Interface product and supports the NGX and 77X in the same way. You can use GIT for everything and it should read in your old config files for NGX/77X. Having said that I'm not aware of any issue in running them all together.
I'm no Q400 expert. Slayer wrote the config and is very helpful in getting it working for people. Wait for him to chip in as he has got it working for a couple of people with similar issues. There are a few recent threads on the Q400 have you checked them for assistance?
Thank you for the reply. Your GIT is awesome. I found all my problems. As much as I tried to keep my old interfaces I was unsuccessful. I got your interface working fine with the MQ400 but it did interfere with the old interfaces I had installed. So I got rid of them and then found out that my PMDG 737NGX would not work with your interface. But that was my fault, last night I found out that I did not have the new update for the 737 NGX installed.
I will download that today. The T7 works just fine. Your GIT works great as well with the Q400. The only thing that wasn't working was the vertical Speed Control. So I ended up creating a couple of macros with FSUIPC, one for a positive direction and one for a neg. direction. Just used the right and left click of my mouse on the Vert Knob to set this up. Does the job.
So all good. Another thing I noticed was that the detective wasn't active with the 737ngx and the T7 but I didn't need to set anything up with these two aircraft it worked as soon as I installed your GIT.
Anyway my worry was all for not regarding getting rid of my old interfaces. Yours is awesome.
My hardware is as follows: Precison Flight Control Yoke, MCP Pro & EFIS, Saitek Throttle, Cessna Rudder Pedals, and I also have the Jetmax (Flight Deck Solutions) CDU. This is an awesome CDU, I would highly recommend it. Bit expensive but worth every penny. I'm using two monitors, 27' and 32".
I learned a lot from your forum. You guys are great.
Thanks again
Wayne
I should clarify, in previous post I said both the 737 and T7 work with your GIT. The T7 did, I still need to download the new version update today for the 737. However I am sure it will work OK once I download that. It has a lot of the same stuff the T7 has on board and the T7 works great.
All the Best
Wayne
