Current Reported Bug List - GoFlight Interface Tool X-Plane
2.0.140
- None reported.
2.0.13.0
- RunLUA Tasks not working, loading as Remark Tasks. Fixed in 2.0.14.0
2.0.12.0
- Devices not syncing switches properly when assigned Lua code. Fixed in 2.0.13.0
- Datarefs.txt, Commands.txt, DRE.txt and DREDatarefs.txt are not being copied during Import in some situations. Fixed in 2.0.13.0
- Some customers have reported issues with inconsistent lights on the MCP PRO for some aircraft. Not clear if its a config issue or a GIT issue. Fixed in 2.0.13.0
2.0.11.0
- Renaming an Lua file outside of GIT then loading GIT and going to the Lua console causing a crash. Fixed in 2.0.12.0
- Any Lua filename containing start wrongly executes as a continuous Lua script resulting in a crash. Fixed in 2.0.12.0
- Importing Lua files via wizard is not creating Bespoke Events correctly causing collection exceptions. Fixed in 2.0.12.0
- Devices not syncing properly when assigned Lua code.
- Some custom datarefs do not appear to work in Fixed View although they show up in standard view. Fixed in 2.0.12.0
- Unable to Export Bespokes if the current active Bespoke is blank. Fixed in 2.0.12.0
- GIT unresponsive on exit. Fixed in 2.0.12.0
- Some plugins (currently an additional FMC for the EADT x737 models and JARDesign's Ground Handling Deluxe) are opening and not closing DREDataRefs.txt causing a "GIP - Message Processor Exception: The process cannot access the file ..." error in the log resulting in GIT becoming stuck. Fixed in 2.0.12.0
2.0.8.0
- Using search facilities in the config tabs is causing a stack overflow and lockup.
2.0.3.0
- Array datarefs are not working. Impacting LGT where lights are not working properly. Fixed in 2.0.6.0
1.9.0.0
- GF46 Alert Display has reverted to post development. Impossible to configure alerts. Not sure when this happened. Fixed in 1.9.1.0
1.8.0.0
- GF45/46 need Light Actions so radio data can be formatted correctly. Hard coded into 1.9.0.0
- The Import Function on Detective is causing GIT to lock up. Use the Import wizard in the meantime. Cannot replicate in new version. Closing.
1.7.0.0
- Missing code for ForceDataRefreshAlternative method that may be causing lock ups. Fixed in 1.7.1.0
1.6.5.0
- GF166_DEVICE<n>_ACTIVECONFIG Datarefs are missing. Fixed in 1.7.0.0
- GF45 Non Pushed Event fields (Right Knob) are configurable but display the Pushed Event fields (Left Knob). Fixed in 1.7.0.0
1.6.4.0
- Possible issue with IXEG (under investigation) Fixed in 1.6.5.0
1.6.1.0
- With the Carenado planes, cannot access the menu, left side bar that has the views and options on all their planes, nor the auto pilot with the C90. GIT Plugin replacement hotfix is here: https://www.dropbox.com/s/5fwng749kd1hdik/GIT Plugin.zip?dl=0 Fixed in 1.6.2.0
1.6.0.0
- Issue whee datarefs.txt and commands.txt are not importing via the Import Wizard. Fixed in 1.6.1.0
1.5.0.0
- VCRUNTIME140.dll missing error. Install the MS Runtimes from here to fix until next release. Fixed in 1.5.1.0
- Non English language versions of Windows is causing import errors for Bespoke Events containing decimals. Fixed in 1.5.1.0
1.3.0.0
1.0.0.0
