It might be that the math is slipping back into German Culture when the Bespoke Event runs and the result is ending up incorrect or zero. I'll follow the code through and see if I can spot something.
Finally fixed the problem. It was specific to non English windows users.
A new version of GIT is available to download now that will resolve the issue. It will also now load Dataref.txt as well as DataRefs.txt as the EADT uses that particular filename.
Works perfect. Thanks for the great work on Sunday!
Great news. I had to convert my Windows development environment to German at least 6 times to track that nasty little bug down! Not my ideal way to spend 6 hours on a Sunday but very glad its all working now.
My MCP pro works partialy. Just The course,heding & speed rotary are working. the other ones are not.There is no desplays all are dark.
The same happend with te 166A & 46. The rotaries and flips are working, but not the diplays.
Can anyone, help me?
Rene
Thank you.
This morning i`ve uninstal GIT (1.6.5) and i`d instal it again. Finaly the MCP display, Course, heading and speed rotarys are working. I stil have problems with the rest of the MCP (any switch & any buton works).
When i pause and unpause the toggle on the ditective and move a switch on the 2d cockpit(Dir or light switch) after hide the data refers, nothing happends on the monitor area.
I tried to imprt data refs from the aircraft zip. but every time the GIT turns off.
I don know if there is a way to create bespokes & variables manualy (taking Data refers from the x737 folder?.
By the way, all the 166 are all ready working grate.
Rene
If it is still not working, go to your MCP tab and click the import button there and again point it to where you unzipped the files.
If you are still having issues, there is a log window pls copy the text in there and padte it here so Steve can see whats going on.
I tried in both ways. the progam ask for an xlm file. But i can´t find any one
The problem is when i´m using the x737 only. If i use an other aircraft, every thing is ok,
I have Windos 7 in spanish.
Last night using the detective i´ve alredy programed the MCPPRo´s switches and buttons. I´m stuk on the altitude and VS rotary values.
Rene
It is done
Rene
