MC PRO
Hello,
I have installed the payware version after desintalling the freeware one, and now I have a problem : no lights working on the MCP (no leds, no digits).
but when I turn the knobs, there is an action on my aircrafts (PMDG 777 and NGX)
I'm on P3D 3.2
Any solution?
Thank's and best regards
Yves
I'm on P3D 3.2
Any solution?
Yves
Hi Yves,
GIT is now complied against the very latest version of the P3D SDK (3.2.3.16769) so that all the new events are available. It may be you are using a slightly older version?
Any solution?
thank's
Yves
Are you running version 3.2.3 of P3D?
I've just tested it and its OK on my system. Check the FAQ entry titled My MCP PRO or MCP Advanced is not updating its display (just showing zeroes):
http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
Everything worked with the free release.....
Well I'm out of ideas then. I will have to think about what else it could be.
Can you check your 777 version is 1.10.7025 via the Operations Center.
have a good weekend
Yves
