Current Reported Bug List - GoFlight Interface Tool
3.6.10
- GSX FSDT LVars are not being found in Detective.
3.6.0.0
- SendKey does not work across a networked PC.
- RunLUA Tasks not working as they are being loaded as Remark Tasks. Fixed in 3.6.1.0
3.4.10.0
- A few customers have reported issues with PMDG aircraft and P3Dv4. Work around is to use GIT 64Bit BETA assuming all other issues from the FAQ have not resolved the problem. Fixed in 3.6.0.0
- PMDG 747 is not working for some customers when used with P3D 4.1 and 4.2. Fixed in 3.6.0.0
- Renaming an Lua file outside of GIT then loading GIT and going to the Lua console causing a crash. Fixed in 3.6.0.0
- Any Lua filename containing start wrongly executes as a continuous Lua script resulting in a crash. Fixed in 3.6.0.0
- Importing Lua files via wizard is not creating Bespoke Events correctly causing collection exceptions. Fixed in 3.6.0.0
- Devices not syncing properly when assigned Lua code. Fixed in 3.6.0.0
3.4.7.0
- Crashes have been reported in various situations. Issue tracked down and fixed. Fixed in 3.4.8.0
3.4.6.0
- Using search facilities in the config tabs is causing a stack overflow and lockup. Fixed in 3.4.7.0
- Crashes have been reported in various situations. Currently being investigated.
3.4.4.0
3.4.0.0
3.1.0.1
- Failing to connect with PMDG aircraft when a TQ6 is not attached. Fixed in 3.4.0.0
3.1.0.0
- PMDG 777 and 747 with the MCP PRO do not work. Fixed in 3.1.0.1
3.0.0.0
- GF166 Default buttons for COM, NAV and ADF are causing GIT to crash when clicked. Fixed in 3.1.0.0
- GF46 Alert Display has reverted to post development. Impossible to configure alerts. Not sure when this happened. Fixed in 3.1.0.0
2.747.1.0
2.5.5.0
- Importing some profiles into Detective is causing the following error: "import has failed: Data at the root level is invalid,Line1, position 1."
- Joysticks not working. Fixed in 2.6.0.0
2.5.1.0
- A rare situation where certain Joystick combinations will cause Bespoke Events loading to fail and no configuration can occur even though Enable Joysticks is disabled. It would also cause GIT to freeze when used with the NGX and 77X. Fixed in 2.5.5.0
2.5.0.0
- Installer thinks its the X-Plane version. Fixed in 2.5.1.0
2.4.0.0
- Loading Q400 was causing multiple errors. This is due to obfuscation. Fixed in 2.4.1.0
2.3.0.0
- Non English language versions of Windows is causing import errors for Bespoke Events containing decimals. Fixed in 2.4.0.0
2.2.4.1
- The GF166 control events are not working. Fixed in 2.3
- Joystick tab shows Import All and Export All when in fact only the current device is imported/exported. Button names need changing. Fixed in 2.3
- Bodnar Button Box import is failing.
2.2.4.0
- Crashing on start-up due to obfuscation. Fixed in 2.2.4.1
- Enabling Panel Serialisation in P3D v3 causes GIT to generate errors and remove Bespoke Events. Fixed in 2.2.0.0
2.1.19.4
- Detective tasks are showing as _NO_DATA. Fixed in 2.1.19.5
2.1.18.9
- 777X and the TQ6 is missing events list. Fixed in 2.1.18.10
- Joystick POV's are not working. Fixed in 2.1.19.4
- Joystick configs are staying present in GIT when aircraft loaded with no Joystick config. Fixed in 2.1.19.4
2.1.18.4
- Bespoke vars are not renaming properly. Fixed in 2.1.18.8
- Joystick buttons limited to 25, should be 32. Fixed in 2.1.18.6
- Importing some profiles into Detective is causing the following error: "import has failed: Data at the root level is invalid,Line1, position 1." Profile authors need to re-export their profiles using this version or above: https://www.dropbox.com/s/wdjqnj54jh6tftq/GoFlightInterfaceToolP3D_Setup_2_1_18_7.zip?dl=0
2.1.18.0
- Using FS Default button on the MCP tab causes a crash. Fixed in 2.1.18.4
2.1.16.0
- Aircraft short names are not working. Fixed in 2.1.17.0
- Clicking FS Default on MCP PRO causes GIT to crash. Fixed in 2.1.17.0
- Simconnect variables are not updating in Prepar3d version 3. Fixed in 2.1.17.0
- dll.xml file is not created for start-up of the Goflight Interface Module.dll if the dll.xml file does not exist. Fixed in 2.1.17.0
2.1.15.0
1. Out of bounds error. Fixed in 2.1.16.0
2. Detective button disabled. Fixed in 2.1.16.0
For both of the above issues install the 32bit version of the following: https://www.microsoft.com/en-us/download/details.aspx?id=48145
2.1.14.2
1. TPM is not showing up in Joysticks. Fixed in 2.1.15.0
Please report any other bugs in the technical support forum and I'll update this list as necessary.
