Just a quick Q GFIT and Carenado.
Is it possible I am doing something wrong or it is a problem with carenado B1900D?
There is on rocker switch (MASTER LIGHT SWITCH) that has to be ON to be able to operate others lighting switches, on the detective  I press LVARS and EVENTS  it goes through the cycles I then hide all detected I only see the LVAR for the switch
ASD_MASTER_SITCH_POWER_LIGHT  = 0  for off
ASD_MASTER_SITCH_POWER_LIGHT  = 1 for on  But there are no EVENTS so I can't get it to work.
Rick
  • Hi Rick,
    Just create two Bespoke Events, one for turning it on and one for turning it off. For the Bespoke Event for on, use the Set Task to set ASD_MASTER_SITCH_POWER_LIGHT to 1 and for the off Bespoke Event use the Set Task to set ASD_MASTER_SITCH_POWER_LIGHT to 0.
    You can then assign these Bespoke Events to your GoFlight hardware.
