Version 2.1.15.0 for FSX problem
Version 2.1.14 of GIT worked for me , but I installed the Version 2.1.15.0 to get the benefit of new support for the GF-TPM module.
I use Windows 7 Professional 64 bit.
I uninstalled V2.1.14 and then installed V2.1.15.0. Rebooted and then started FSX and GIT.  Then went into the 3D virtual cockpit of an aircraft.
The yellow light for SimConnect/FSX came on a stayed.
All of the device tabs as well as the Joysticks tab remained greyed out.
The Log tab showed the output over two screen loads as follows:
Any ideas of what the problem could be?
The GF-TPM module is detectable by FSUIPC, but is deconfigured as a joystick on the aircraft I'm trying to setup using GIT.
Regards,
Ian
