GIT PMDG Unresponsive: FSX: Steam
Working fine since operational back mid-October, but now the Menu comes up and Tabs are not highlighted---it does show my GF hardware. Also SimConnect/FSX is Green(GF hardware works in default FSX). When I move cursor to the Menu box, the box doesn't move.Have to use Task to shut it down.
Doug
Hi Doug,
It may be corrupt setting files. Rename My Documents\GoFlight Interface Tool to something else so GIT resets and try again.
Hi Doug,
Have you ran chkdsk on your drive as it sounds like its corrupt and messing everything up. Select Properties of your drive via Windows Explorer, then Tools and click the Check button.
If you go into your steam library and select the properties on FSX SE, then select the Local Files tab and click Verify Integgrity of Game Cache.
It might be worth re-installing GIT as well.
Bring up the Steam front end/program and click Library so your games are listed.
