X-Plane FlightFactor 757 V2 EFIS + MCPPro + GF 166
This is for the new V2 version of the Flightfactor 757 - please don't attempt to mix with the old one.
Steve McNitt
Many Thanks
Paul
Thanks for your reply
I have had a look for the document you mention but cannot seem to find it
I have shortened the name of the zip to 757 but still no joy but obviously there is more to do
Thanks in advance
Paul
Load up the aircraft and GIT. Go to the Settings tab in GIT and shorten the name there, remembering to click OK.
Thank you for your help
I do as you suggest and shorten the aircraft name to just 757
I click OK then no twice
But it does not save and when reloading the GIT it defaults back to both 757-200 and 300
It does work very well in the 200 but not the 300
I am sure I must be missing something simple
If you require any further information please just ask
Many Thanks
Paul
I now only have Zero's on the MCP and it does not interact with the aircraft
Thank you for your support
Paul
Heading out for the day now.
Cheers
Paul
a workaround is manually adding these datarefs to datarefs.txt and then delete/reimport again.
The name has been shortened to work with all the variants.
I am using the latest GIT for my MCPPro, EFIS, 2x GF-166 and a GF46.
When I have the FF757-200 v2 loaded the sim crashes when doing anything in GIT. Whether it is attempting to import a profile, or just restarting GIT to get the MCPPro to work. Been working on this for a few weeks now.
I have no problems with GIT when using any other aircraft in X-Plane 11, like the Zibo 737-800X, the Rotate MD80 and the LevelUp 737NG's
Thx for your reply
