Apologies to Steve
Re: your reply to my post on the Avsim PMDG forums (17th Nov.) regarding GIT. I did not mean to demean your product, as I have it myself. You are quite correct as to the ease of use with regard to the MCP Pro and EFIS. It just does what you said it would do. How ever, I have 5 GF 166 units and cannot get them to work. Is there a simple how to guide for these somewhere, its getting quite frustrating, having them just sitting there, and not doing anything !!
Neil
Hi Neil,
Can you not configure them or are they locking up/restarting etc,
Hi Neil,
The devices are not disabled. The fields are not populated until you select a device and which point the fields are enabled and the data updated. By default when no device is selected it shows disabled.
Your problem sounds like you have something else also driving the units. Have you built a configuration in GFConfig with everything turned off for the devices and ensured its loaded before using GIT?
