LeoBodnar BBI-32 & GIT 2.6.0.0 P3D version - issues/crash
I just received a BBI-32, as I had noticed earlier version ChangeLog mentioned you had added support for this card in GIT.
I plugged it in, and my system recognized the card.
I couldnt find any tab for the BBI-32, so I assumed that it might come under the 'Joystick' tab, which was greyed out as I have not enabled this option.
I went to the settings tab to enable Joysticks, and Save Settings.
I then quit GIT and relaunched it, when a warning advised me to save all my settings, and that it was
"Unable to Load Bespoke Events:Index was outside the bounds of the array"
Haven taken a backup, I clicked OK and GIT showed all tabs as greyed out.
Status tab showed it had recognized all of my GF hardware, but all tabs were greyed out, including the Joystick tab.
I clicked on the restart button in GIT, and got the same warning, but this time the Joystick tab was active (but all other GF tabs still greyed out).
I was able to see the BBI-32 card in the list of joystick deices, enabled it, saved a function to button 1, and then went to the Settings tab.
Just before I hit the save Settings button, I noticed the Enable Joystick checkbox was not ticked
I can only return GIT back to its normal working condition if I directly edit the Settings.xml file and set <JOYSTICKSENABLED Enabled/> to False
Hi David,
Some joysticks crash GIT which is why the option is disabled by default. Can you remove the BBI-32 and then enable the joysticks option and see if GIT still crashes. If so we need to determine which Joystick device is causing the problem. The best way to do this is connecting the joystick devices one at a time. Once you have identified the offending device, copy and paste the GIT Log and attach it to this thread.
thanks for the reply.
I have removed all of the joystick devices that I could and tested after removal of each one.
There is one remaining, that I am not able to remove, as its a virtual driver, and even in the hardware manager config page, I am not able to disable this virtual driver.
I do actually depend on this virtual driver for this device.
Anyway, the driver/virtual device is:
3Dconnexion KMJ Emulator
and allows the 3DConnexion device to appear as a joystick device.
The GIT log contained this:
18:10:51 GoFlight Connection Starting.....
18:10:51 SimConnect Connection Starting.....
18:10:52 SimConnect Message Processing Started
18:10:52 GoFlight Connection Started
18:10:52 SimConnect Connection Started
18:10:52 Aircraft Connection Starting.....
18:10:52 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
18:10:52 SimConnect: Event Received: SIM, 1
18:10:52 SimConnect: Event Received: PAUSE, 0
18:10:55 FSUIPC: Connected!
18:10:55 Aircraft Connection Started
18:10:55 Simconnect Version: 3.2.0.0
18:10:55 Synchronising Switches & Selectors .....
18:10:55 LvarNamesUpdated!
18:10:55 Creating Bespoke Vars
18:10:55 Bespoke Vars Created
18:10:55 Importing Bespoke Variables
18:10:55 Bespoke Vars Assigned, Importing Bespoke Events
18:10:55 Bespoke Events Temp Imported
18:10:55 Bespoke Events Imported
18:10:55 Loading Aircraft Settings
18:10:55 GetXMLConfigData
18:10:55 GotXMLConfigData
18:10:55 Loading Power
18:10:55 FP Device Found: 3Dconnexion KMJ Emulator
18:10:56 Device Found: Audio Controls
18:10:56 Device Found: USB Keyboard
18:10:56 Device Found: GoFlight GF-P8 control module
18:10:56 Device Found: GoFlight GF-RP48
18:10:56 Device Found: WCP
18:10:56 Device Found: GoFlight GF-T8 control module
18:10:56 Device Found: HID-compliant device
18:10:56 Device Found: MESM
18:10:56 Device Found: LGTII
18:10:56 Device Found: GF-166
18:10:56 Device Found: MCP PRO
18:10:56 Device Found: GF EFIS
18:10:56 Mouse Device Found: Mouse
18:10:56 Keyboard Device Found: Keyboard
18:10:56 Joystick Found Device 0: 3Dconnexion KMJ Emulator
18:10:56 Device 0 Button Count: 4
18:10:56 Device 0 POV Count:1
18:10:56 Loading MCPPRO
18:10:56 Loading EFIS
18:10:56 Loading P8
18:10:56 Loading T8
18:10:56 Loading RP48
18:10:56 Loading MESM
18:10:56 Loading WP6
18:10:56 Loading LGT
18:10:56 Loading LGT II
18:10:56 Loading GF46
18:10:56 Loading GF45
18:10:56 Loading TQ6
18:10:56 Loading DIO
18:10:56 Loading GF166
18:10:56 Loading SECM
18:10:56 Loading Joysticks
18:11:07 SimConnect: Exception Received: NAME_UNRECOGNIZED
18:11:21 Synchronising Switches & Selectors Complete
Hope this helps
Great, I'll build a test version for you that excludes that device. Since your email address is not listed in the Shop, I need you to PM me your Shop email address or login name and invoice number.
That worked - many thanks.
