GIT, IXEG 737 and Auto Throttle
I'm having an issue with GIT, using the auto throttle with the IXEG 737. When I arm the auto throttle, the throttles immediately increase to full power. After activating TOGA the engines reduce to take off thrust then once in the air one engine reduces to idle.
I have the latest GIT downloaded, the lastest new version of x-plane 11.
I have deleted all the current Bespoke events and updated them with the Import Wizard.
This error does not occur if I arm the auto throttle clicking the mouse on the switch, but only arming the a/t using the Go-Flight MCP-Pro.
Any thoughts welcome.
Cheers
Graham McAllister
  • Not seeing that behaviour here
    Steve McNitt
  • This is what detective changes when the MCP-Pro switch is changed. Switching the A/T ARM by mouse doesn't implement any of these changes. I'm assuming you're unable to shed any light on the problem?
    0000260863    DataRef : sim/cockpit/autopilot/airspeed_mode    DataRef Data: 10
    0000260864    DataRef : sim/cockpit/autopilot/autopilot_state    DataRef Data: 165
    0000260961    DataRef : sim/cockpit2/autopilot/autothrottle_enabled    DataRef Data: 1
    0000260962    DataRef : sim/cockpit2/autopilot/autothrottle_on    DataRef Data: 1
    0000276745    DataRef : sim/cockpit/autopilot/airspeed_mode    DataRef Data: 9
    0000276746    DataRef : sim/cockpit/autopilot/autopilot_state    DataRef Data: 164
    0000276839    DataRef : sim/cockpit2/autopilot/autothrottle_enabled    DataRef Data: 0
    0000276840    DataRef : sim/cockpit2/autopilot/autothrottle_on    DataRef Data: 0
    Cheers
    Graham
  • I only change the state of the auto throttle switch.The rest is done by the aircraft itself
    Feel free to open the detective and look at the bespoke event.
    I suspect some other issue causing the throttle to firewall like that
    Steve McNitt
  • Hi Steve, just a little feedback after solving my issue, finally this morning.
    For some reason another plugin had been installed, XPGF. Removing this from the plugins folder finally has the MCP-Pro and EFIS working correctly.
    Cheers
    Graham
