Development Plan - GoFlight Interface Tool
- Bespoke variables. Added in 2.0.697.0
- Clear function on each tab to wipe settings. Added in 2.0.383.0
- Default FS function for MCPPRO and MCP to assign default simconnect events and variables. Added in 2.0.301.0
- Add an if..else function to Bespoke Events. Cancelled as un-necessary.
- GF166 Support. Added in 2.0.327.0
- Support for Axis - any device but initially for the TQ6. Support added in 2.0.491.0 & 2.0.536.0
- GF-TPM Support. Added in 2.1.15.0
- GF-SECM Support. Added in 2.0.1003.0
- Messaging for GF46. Added in 2.2.0.0 / XP 1.4
- Full simconnect support for the PMDG NGX. Support added in 2.0.823.0
- Support for the PMDG 777. Added in 2.1.3.0
- Memory offset support. Added in 2.2.0.0
- Facility to execute long running Bespoke Events in the background. Added in 2.0.345.0
- Round function for displays to round the values up. Added in 2.0.254.0
- Turn off all displays and LED's when power cut from aircraft. Added in 2.0.947.0
- Ability to change brightness of Goflight devices. Support added in 2.0.823.0
- Show gear in transit lights on the LGT/LGTII. Done.
- Add all door support to NGX. Support added in 2.0.823.0
- Support for readable and editable xml settings file. Added in 2.0.588.0
- Simconnect variable support in Bespoke Events. Added in 2.0.632.0
- Add support for the Leo Bonar Button Box Interface BBI-32. Added in 2.2.0.0
- Add support for push and rotate. Added in 2.2.0.0 / XP 1.4
- iFly 737/747 support. Added in 3.2.0.0
- Add press time for SendKey tasks. Added in 2.1.18.8
- Enable Bespoke Events to call other Bespoke Events. Added in 2.1.18.8
- Enabling joystick support to be limited to each individual aircraft. Added in 2.1.18.8
- Add support for Off and Hold on joystick buttons. Added in 2.1.18.8
- Add support to specify the button repeat time. Added in 2.2.0.0 / XP 1.4
- Add GF166 export/import function. Added in 2.2.0.0 / XP 1.4
- PMDG 747 v2 Support. Added in 2.747.0.0
- Add exactly the same functions available in GFConfig for the GF46. Added in 2.5.6.0
- Implement acceleration algorithm for Bespoke Events/Mouse Click Events. Added in 2.3.0.0
- Add ability to switch on GoFlight devices based on Avionics power state. Added in 3.1.0.0
- Add Bespoke Event to allow for comments/remarks. Added in 3.0.0.0
- Add search facility for events and variables. Added in 3.2.0.1
- Add some Detective functionality for PMDG and iFly aircraft. Use GIT Lua scripts instead of Detective.
- Check/enable reverse throttle functionality for GA aircraft such as the Duke.
- Investigate use of voice commands to control GoFlight hardware when using Virtual Reality.
- Facility to print out config details for each device.
- Add Arduino board support.
- As an alternative method to display blanking have a 3rd option to use "--------" Like the Airbus displays
- Add facility for creating virtual GF Devices.
- Associate Simconnect Event ID's to Bespoke Events so voice control in P3D v4 can activate them.
- Attempt to add missing functionality to FS2020 version, because MS took a sledge hammer to the SDK! :-[
- Add facility to stop auto configuration for PMDG aircraft on the LGT/LGT II.
Please add development requests in this forum and if suitable, I will add them to the development plan.
This discussion has been closed.
