Back but obviously done something wrong
Hello
been away from my PC due to personal circumstances for a few months, tried to fire up Prepar3d with the Dash 8 and goflight interface and I cannot do anything, cannot select detective or use the import wizard, seem to be locked out. get loads of simconnect errors in the log of the interface tool. have I downloaded some wrong drivers etc..... can anyone help this poor soul?
thanks in advance
16:37:12 SimConnect Connection Starting.....
16:37:13 SimConnect Message Processing Started
16:37:13 GoFlight Connection Started
16:37:13 SimConnect Connection Started
16:37:13 Aircraft Connection Starting.....
16:37:13 SimConnect: Event Received: Aircraft Type Changed
16:37:13 SimConnect: Event Received: SIM, 1
16:37:13 SimConnect: Event Received: PAUSE, 1
16:37:13 GoFlight Connection Starting.....
16:37:13 SimConnect Message Processing Finished
16:37:14 SimConnect Connection Starting.....
16:37:14 GoFlight Connection Started
16:37:15 SimConnect Message Processing Started
16:37:15 SimConnect Connection Started
16:37:15 Aircraft Connection Starting.....
16:37:15 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
16:37:15 SimConnect: Event Received: SIM, 1
16:37:15 SimConnect: Event Received: PAUSE, 1
16:37:16 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:18 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
16:37:18 Aircraft Connection Started
16:37:18 Simconnect Version: 3.2.0.0
16:37:18 Synchronising Switches & Selectors .....
16:37:18 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:19 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:20 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:21 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:22 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:23 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:24 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:25 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:26 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:27 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:28 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:29 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:30 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:31 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:32 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:33 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:34 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:35 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:36 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:37 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:38 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:39 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:40 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:41 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:42 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:43 SimConnect: Exception Received: OUT_OF_BOUNDS
16:37:45 Synchronising Switches & Selectors Complete
See the FAQ entry "The Log is showing "SimConnect: Exception Received: OUT_OF_BOUNDS". The FAQ is here: http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
