Help
I have tried hopelessly to install this software to use my mcp pro with xplane. can someone please help me with a step by step on where and how to install? Many thanks...
Follow the installation instructions here http://www.pollypotsoftware.org.uk/support/user-guide/goflight-interface-tool-x-plane/33-installation/78-installation.html
Start GIT, then X-Plane. You should have 3 green LED's. Select the aircraft you wish to use with GIT in X-Plane and get to the virtual cockpit. Once the MCP PRO tab become enabled, you either use a pre built config for the aircraft if available (found in the Downloads section of the website) or click the FS Default button on the MCP PRO tab if its a standard X-Plane aircraft (remember to enable the MCP PRO in GIT).
No. It sounds like you haven't installed that particular plugin so you can ignore that part of the instructions.
PS The other LED's should go green when X-Plane is started.
If you are referring to the GIT Plugin, it is installed during the setup process, you should have confirmed its location during setup (e.g. the X-Plane directory). If you installed it correctly, you should see a GIT Plugin directory under resources/plugins of the X-Plane directory.
Note that the GoFlight Interface Tool should be installed in c:\program files (x86).
Steve - I did mention that I was installing this in xplane 11 correct? When I purchased the GIT I still had Xplane 10...is that an issue?
Thanks,
Mike
Its not an issue so long as you have downloaded version 1.8 of GIT.
