GF-LGT-II Not Working
I'm having a problem with LGT and perhaps you may help. LGT LG lever only works for the "gear down" command, not for the "gear up". The rest of LGT works fine and I am not running the GoFlight Data Bridge.
Any ideas?.
Which aircraft are you using?
How did you configure it? Did you use FS Default button? Is it the LGT or LGT II that you have?
Can you zip up My Documents\GoFlight Interface Tool and attach it to this thread.
There are missing settings for the Duke and the LGT II. When the plane is loaded up. Clear the device config for the LGT II by pressing the Red X on the LGT tab and then click the FS Default button to reconfigure.
