Feature request for Bespoke Events - Read/write offsets
HI,
Would it be possible to add some function calls to enable reading and writing offsets from FSUIPC variables?
For example, one aircraft publishes a table of all variable offsets, such as:
FSUIPC Variable:
7390
Length(bytes)
1
Read bits to Function:
get LED status :
Length(bytes)
1
get LED status :
0 PACK1 FAULT
1 PACK1 OFF
2 PACK2 FAULT
3 PACK2 OFF
4 ENG1 BLEED FAULT
5 ENG1 BLEED OFF
6 ENG2 BLEED FAULT
7 ENG2 BLEED OFF
Hi David,
As far as I know, FSUIPC does not provide developer access except via LUA. So I can't do anything directly, but you could write LUA scripts and then create Bespoke Events to execute the scripts.
