Lights?
Under the menus... I am confused about what lights, non pushed, pushed, rotary, non rotary.. All mean?
  • Using Xplane 11...for a 45 and 166a
  • Hi Roger,
    Pushed is when the grey rotary dial is pushed and turned and Non-pushed is when its simply turned.
    Having looked at your config file, the GF166 is only setup for the Cessna_172SP and the Baron_58 so can you re-check the GF166 with these aircraft.
  • How do you set up for other planes please?
  • In the same way as the others you have setup.
  • Thank you so Much, it worked perfectly only needed to update this once. :smiley:
