GIT 'frozen' on desktop
Running latest version of GIT without any problems...except very recently.
The GIT comes up on the desktop, but all of the tabs are un-clickable: Nothing is activated by the cursor. I've reinstalled, but same problem.
Thanks for sleuthing this.
Doug
"It may be corrupt setting files. Rename My Documents\GoFlight Interface Tool to something else so GIT resets and try again.
Doug
Sorry for the late reply.
If the UI is semi responsive (e.g. you can exit GIT or click about it may be that The GIT module is not running (usually indicated by lots of Out of Bounds errors).
There is an entry called in the FAQ called "FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module" which is worth checking.
If its locking up completely you need the latest Goflight drivers available from the top of the forum installed into the GIT directory.
If you have a SECM and the old GFDev.dll is in the GIT installation folder it will lock up.
The drivers at the top of the forum are GoFlight's very latest unreleased drivers from a week or so ago. If those don't work, try these https://www.dropbox.com/s/qj9l968zsp7313p/GFConfigSetup_2_26_5.zip?dl=0
Its very important that GFDev.dll is replaced/updated, so uninstall the Goflight drivers before installing any other version.
Will do,,,,many thanks, Steve.
Hi Tim,
The 2.26.1 drivers had a SECM bug, so GoFlight provided me with 2.26.5 which only this website provided. Looks like I have posted the 2.26.1 drivers up by mistake when putting up the alert. Well spotted.
The latest versions and release dates are always listed here: http://www.pollypotsoftware.org.uk/support/update-news-rss-feed.html
The download count is reset whenever a new version is posted. You can also ask to have it reset. Its only there to restrict casual software piracy.
I don't see any major GIT for X-Plane updates in the near future. No-one is reporting any problems.
GIT has been updated to solve this problem
