STAB TRIM value for GF46 B737NG
Hello, how I can assign STAB TRIM value from left or right trimscale center pedestal to GF46 indication for a B737NG?
Best regards
FSAM
Assign EVT_CONTROL_STAND_TRIM_WHEEL as the Event. Couldn't find any NGX specific variable for the actual value, so it may be available using a Simconnect variable related to trim.
PS, if no luck ask PMDG what the variable is.
fsam
That is the correct event as its pre-configured on the GF LGT's. Did you use ROTATE as the Event Action?
yes, I'm using this event with ROTATE and it works, but I can not see the STAB POS IND since there is no varible for it to assign.
The control is not the Problem, the indication is what I'm looking for.
Best regards
fsam
