PMDG Interface Connection Error
Steve:
Please hlp me with the issue, "GoFlight Worker Thread Failed..Index was outside the bonds of the array"
My motherboard crashed and had to install a new one and obviously something got changed.
I'm using Version 1.1.0.0 and since it was working fine, I didn't upgrade which I will get around to but don't want to lose my assignments (or learn how to copy them) as there is so much to do to get FSX back as it was before the crash.
Thanks.
Mark Kessinger
Hi Mark,
Have you installed the interface into the goflight directory where gfdev.dll exists. If not you have to set the goflight directory n the settings tab.
Yes it's there: (GF PMDG) interface.exe, interface.exe.config, interface.exe.manifest, interface.InstallState
It was working fine until motherboard change.
Mark
Got it. Thanks for your help-loose usb/motherboard issue.
Mark
Hi Mark,
The error can also be caused by older Goflight drivers.
