Freezing of GFIT while I push the import button in Detective mode
hi Steve,
when i want to load the available configuration , after pushing the import button in detective, the soft ware freezes and GFIT not responding, please let me know what is the problem?( for MCP PRO and EFIS in Xplane 11, B737,OS Windos7)
Thank you.
Firouz
  • Which 737 aircraft are you using, default, EADT or IXEG? If its default, where did you get the config from as I don't have it listed in Downloads?
  • HI,
    default and EADT, and x737 project,in all these three aircraft.
    Thank you for your support.
    Firouz
  • Can you rename My Documents\GoFlight Interface Tool and then run GIT as Administrator and try again.
  • Hi Steve.
    I change the Goflight interface tool name to GIT and run it as an administrator but still while iwant to import B737.xml file in Detective the GFI tool not respond and freeze.
    Thx.
    Firouz
  • I'm concerned that you may be loading the wrong file for the aircraft. For the EADT there is a specific file you need to download from here https://www.pollypotsoftware.org.uk/downloads.html under the GIT Aircraft Configs (X-Plane) tab. Note it is not called B737.xml!
