Programming of LGT II - P3D
Hello all:
in my GF set up, I have a GF-TQ6 and a recently acquired LGT II.
I am trying to re-assign the "Button Flaps Up" and "Button Flaps Down" events to "Parking Brakes", "Blank", etc., so that the flap lever on the TQ6 commands the flaps, and the LGT II flap switch, does not continuously fight with it.
Regardless of the input event selected (i.e. the "Parking Brakes" activate when I move the LGT II flaps switch), the flaps continue to activate! Even with the event "off" (I imagine that the input "Default FS" assignment has something to do with this).
In the GF Config, everything is unassigned in the LGT II.
Is there a way to assign a "nothing" or "null" event to the LGT II flaps switch, so that it does not interfere with the flap lever of the TQ6?
Thanks as always.
Roberto
Thanks as always.
Roberto
Make sure GIT has been configured as required and then try quiting the GoFlight Data Bridge (blue icon in the notification area of the Windows Task Bar) when P3D is running and try again. If that doesn't work we have proved that its something other than the GoFlight Drivers/GFConfig so it would be worth checking FSUIPC and the joystick controller in P3D itself.
Thank you.
Quitting the GF Data Bridge worked!
Many regards
Roberto
