GFIT not updating PMDG B737NG
Hello Steve, since I have installed FSX complete new the GFIT did not work with PMDG B737NG, displays will not be updated at GF MCPPRO, Simconnect shows yellow with unrecognized_ID exception. GFIT is working correctly with PMDG B747 and B777. I have read the FAQ and followed the instructions as started FSX new, did not change PMDG's during startup, SDK entry is visible in options.ini, GF drive and GFIT are in same location (c:\goflight) UAC is disabled, running all as admin, changed USB ports, disabled power savings in system, PMDG.xml checked, deleted and rebuilded, de-installed GF and GFIT and installed new - no luck at all. B737NG will not work as expected. During startup all GFIT lights are green, then after receiving the unregognized_ID error the simconnect light shows yellow and Zero at IAS and ALT blänking and no value update to GF Modul.
I'm using:
WIN10 PRO V1703 no add. virus program during downloading / installing procedure except defender itself
FSX SP2 is running stable
GFIT 2.747.1.0 installed and is running with B777 and 747 correctly
GF Driver 2_27_0 complete installed and set to Compatible AddOn
Simconnect is working, e.g. with WX program FSGRW
PMDG NGX 1.10.6461 is used
I have no further ideas, did I miss something or what is going wrong ?
Best regards
  • I would try an uninstall and reinstall of the NGX, remembering to deactivate the NGX license in the FMC.
  • Hello, reinstall of NGX solved the problem, MCP is working as expected, thanks for the hint.
    Best reagrds
