My Flight Director 2 continiously switching on/off
Hi. I moved all my software to a new/old lenovo i5. I installed everything new. Everything is OK except switching FD2 button. One time also vertical speed rotary changed up and down itself but it did not do it again. Also I noticed that green Goflight and aircraft lamps are blinking, while Sinconnect/FSX is stable green. I attached the log file.I hope it is a simple and known problem, easy to fix. Please help me.
Thanks in advance.
20:19:41 GoFlight Connection Starting.....
20:19:41 SimConnect Connection Starting.....
20:19:42 GoFlight Connection Started
20:20:34 SimConnect Message Processing Started
20:20:34 SimConnect Connection Started
20:20:34 Aircraft Connection Starting.....
20:20:38 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
20:20:38 Aircraft Connection Started
20:20:38 Simconnect Version: 10.0.61259.0
20:20:38 Synchronising Switches & Selectors .....
20:20:38 Synchronising Switches & Selectors: Waiting for SimConnect .....
20:20:39 SimConnect: Event Received: Start
20:20:39 PMDG SDK option is OK in FSX
20:20:39 SimConnect: Event Received: Aircraft Type Changed
20:20:39 SimConnect: Event Received: SIM, 0
20:20:39 SimConnect: Event Received: PAUSE, 0
20:20:39 GoFlight Connection Starting.....
20:20:39 SimConnect Message Processing Finished
20:20:40 SimConnect Connection Starting.....
20:20:41 SimConnect Message Processing Started
20:20:41 GoFlight Connection Started
20:20:41 SimConnect Connection Started
20:20:41 Aircraft Connection Starting.....
20:20:41 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:20:41 SimConnect: Event Received: SIM, 0
20:20:41 SimConnect: Event Received: PAUSE, 1
20:20:42 Aircraft Connection Started
20:20:42 Simconnect Version: 10.0.61259.0
20:20:42 SimConnect: Exception Received: EVENT_ID_DUPLICATE
20:22:03 SimConnect: Event Received: SIMSTART, 0
20:22:03 SimConnect: Event Received: SIM, 1
20:22:05 Send Control Data: Too Many Retries
20:22:06 Send Control Data: Too Many Retries
20:22:07 Send Control Data: Too Many Retries
20:22:10 Send Control Data: Too Many Retries
20:22:10 Synchronising Switches & Selectors Complete
Thanks in advance.
Thank you very much.
