I had uninstalled whole window 10 and forget to deactivate GIT
Hi, I has some question. i already uninstall my old Win10 but i think i'm forget to deactivate GIT before uninstall... now i move to P3DV4 with new window but GIT can't work Can you help me? Thank you very much. every time i try to run my PMDG777 GIT log show yellow light and red light and log like this..
9:05:57 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:05:57 Simconnect Version: 3.4.0.0
19:05:57 SimConnect: Event Received: SIM, 0
19:05:57 SimConnect: Event Received: PAUSE, 0
19:05:57 Synchronising Switches & Selectors .....
19:05:57 Synchronising Switches & Selectors: Waiting for SimConnect .....
19:06:05 PMDG SDK option is OK in Prepar3D v4
19:06:05 SimConnect: Event Received: Aircraft Type Changed
19:06:05 SimConnect Message Processing Finished
19:06:06 SimConnect Connection Starting.....
19:06:07 SimConnect Message Processing Started
19:06:07 SimConnect Connection Started
19:06:07 Aircraft Connection Starting.....
19:06:07 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
19:06:07 SimConnect: Event Received: SIM, 0
19:06:07 SimConnect: Event Received: PAUSE, 1
19:06:08 Aircraft Connection Starting.....
19:06:08 SimConnect: Exception Received: ERROR
19:06:09 SimConnect: Exception Received: DUPLICATE_ID
19:06:09 SimConnect: Exception Received: ERROR
19:06:09 Aircraft Connection Starting.....
19:06:10 SimConnect: Exception Received: DUPLICATE_ID
19:06:10 Aircraft Connection Starting.....
19:06:10 SimConnect: Exception Received: ERROR
19:06:11 SimConnect: Exception Received: DUPLICATE_ID
19:06:11 SimConnect: Exception Received: ERROR
19:06:11 Aircraft Connection Starting.....
19:06:12 SimConnect: Exception Received: DUPLICATE_ID
19:06:13 SimConnect: Exception Received: ERROR
19:06:13 Aircraft Connection Starting.....
19:06:14 SimConnect: Exception Received: DUPLICATE_ID
19:06:14 Aircraft Connection Starting.....
19:06:14 SimConnect: Exception Received: ERROR
19:06:15 SimConnect: Exception Received: DUPLICATE_ID
19:06:15 Aircraft Connection Starting.....
19:06:15 SimConnect: Exception Received: ERROR
19:06:16 SimConnect: Exception Received: DUPLICATE_ID
19:06:16 SimConnect: Exception Received: ERROR
19:06:16 Aircraft Connection Starting.....
19:06:17 SimConnect: Exception Received: DUPLICATE_ID
19:06:17 SimConnect: Exception Received: ERROR
19:06:17 Aircraft Connection Starting.....
19:06:18 SimConnect: Exception Received: DUPLICATE_ID
19:06:18 Aircraft Connection Starting.....
19:06:18 SimConnect: Exception Received: ERROR
19:06:19 Aircraft Connection Starting.....
19:06:20 SimConnect: Exception Received: DUPLICATE_ID
19:06:20 SimConnect: Exception Received: ERROR
19:06:20 SimConnect: Event Received: SIMSTART, 0
19:06:20 SimConnect: Event Received: SIM, 1
19:06:20 Aircraft Connection Starting.....
19:06:22 Aircraft Connection Starting.....
19:06:22 SimConnect: Exception Received: DUPLICATE_ID
19:06:22 SimConnect: Exception Received: ERROR
19:06:23 SimConnect: Exception Received: DUPLICATE_ID
19:06:23 Aircraft Connection Starting.....
19:06:23 SimConnect: Exception Received: ERROR
19:06:24 SimConnect: Exception Received: DUPLICATE_ID
19:06:24 SimConnect: Exception Received: ERROR
19:06:24 Aircraft Connection Starting.....
19:06:25 SimConnect: Exception Received: DUPLICATE_ID
19:06:25 Aircraft Connection Starting.....
19:06:25 SimConnect: Exception Received: ERROR
19:06:26 SimConnect: Exception Received: DUPLICATE_ID
19:06:26 SimConnect: Exception Received: ERROR
19:06:26 Aircraft Connection Starting.....
19:06:27 SimConnect: Exception Received: DUPLICATE_ID
19:06:27 Aircraft Connection Starting.....
19:06:27 SimConnect: Exception Received: ERROR
19:06:28 SimConnect: Exception Received: DUPLICATE_ID
19:06:28 SimConnect: Exception Received: ERROR
19:06:28 Aircraft Connection Starting.....
19:06:29 SimConnect: Exception Received: DUPLICATE_ID
19:06:29 SimConnect: Exception Received: ERROR
19:06:29 Aircraft Connection Starting.....
19:06:30 SimConnect: Exception Received: DUPLICATE_ID
19:06:30 SimConnect: Exception Received: ERROR
19:06:30 Aircraft Connection Starting.....
19:06:31 SimConnect: Exception Received: DUPLICATE_ID
19:06:32 Aircraft Connection Starting.....
19:06:32 SimConnect: Exception Received: ERROR
19:06:33 SimConnect: Exception Received: DUPLICATE_ID
19:06:33 SimConnect: Exception Received: ERROR
19:06:33 Aircraft Connection Starting.....
19:06:34 SimConnect: Exception Received: DUPLICATE_ID
19:06:34 Aircraft Connection Starting.....
19:06:34 SimConnect: Exception Received: ERROR
19:06:35 SimConnect: Exception Received: DUPLICATE_ID
19:06:35 SimConnect: Exception Received: ERROR
19:06:35 Aircraft Connection Starting.....
19:06:36 SimConnect: Exception Received: DUPLICATE_ID
19:06:36 Aircraft Connection Starting.....
19:06:36 SimConnect: Exception Received: ERROR
19:06:37 SimConnect: Exception Received: DUPLICATE_ID
19:06:37 SimConnect: Exception Received: ERROR
19:06:37 Aircraft Connection Starting.....
19:06:38 SimConnect: Exception Received: DUPLICATE_ID
19:06:38 Aircraft Connection Starting.....
19:06:38 SimConnect: Exception Received: ERROR
19:06:39 SimConnect: Exception Received: DUPLICATE_ID
19:06:39 SimConnect: Exception Received: ERROR
19:06:39 Aircraft Connection Starting.....
19:06:40 SimConnect: Exception Received: DUPLICATE_ID
19:06:40 SimConnect: Exception Received: ERROR
19:06:40 Aircraft Connection Starting.....
19:06:41 SimConnect: Exception Received: DUPLICATE_ID
19:06:42 Aircraft Connection Starting.....
19:06:42 SimConnect: Exception Received: ERROR
19:06:43 SimConnect: Exception Received: DUPLICATE_ID
19:06:43 Aircraft Connection Starting.....
19:06:43 SimConnect: Exception Received: ERROR
19:06:44 SimConnect: Exception Received: DUPLICATE_ID
19:06:44 Aircraft Connection Starting.....
19:06:44 SimConnect: Exception Received: ERROR
19:06:45 SimConnect: Exception Received: DUPLICATE_ID
19:06:45 SimConnect: Exception Received: ERROR
19:06:45 Aircraft Connection Starting.....
19:06:46 SimConnect: Exception Received: DUPLICATE_ID
19:06:46 SimConnect: Exception Received: ERROR
19:06:46 Aircraft Connection Starting.....
19:06:47 SimConnect: Exception Received: DUPLICATE_ID
19:06:47 SimConnect: Exception Received: ERROR
  • Are you running the P3Dv4 (2.747.3.3) version of GIT? Do you have the GIT Interface Module running in P3D (check the XML.dll file)?
    If yes to both of those questions, try renaming My Documents\GoFlight Interface Tool so you start with no settings as the files may have become corrupt during the transfer.
  • It's still not working can you team viewer and check for me?
  • What version of the 777 are you running?
  • Also have you installed the P3Dv4 hotfix 1?
  • 1.10.8363, sir just dl from pmdg center
  • Yes already. i has upgrade for client and sdk .... or i need more about content too?
  • Those errors make me think the hotfix hasn't been installed or it hasn't installed correctly.
  • ok i will try to install again
  • When i connected with F-22 it all green light....but don't have any light up or digit on my MCP but when use 777 it's can't connect :(
  • In Detective in the F22 when you turn on lvar monitoring do you see a stream of data appear?
    Perhaps a re-install of the 777 now.
  • I saw the data stream ..... in lvar may i re install PMDG again
  • Its the only thing I can think of doing now.
  • Sorry still no luck for me it's still not work
  • Have any more idea?
  • In My Documents\Prepar3D v4 Files, edit the Simconnect.ini file so it looks like:
    [SimConnect]
    level=Verbose
    console=No
    file=C:\SimConnect%01u.Log
    file_max_index=9
    Start GITv4 and P3Dv4 so that the errors occur. A log file will be created in C:\ (or many log files). Copy these and attach to this thread.
  • Ummm now it's worked ...... it's my fault ...... Connected to the wrong port....... Sorry about disturb you T_T
