PMDG B777 P3D vs GIT
Hello to all, and to those of you in Canada, Happy Canada Day!!
After so many updates, P3D came out with its hotfix for v4; PMDG updated (twice) its B747 and B777 for P3Dv3 and v4; GIT was updated to match P3Dv4, so was the GFConfig. I wouldn't really know which one of them to blame for my woes.
I, now, find that the GF-46 module does not work with the PMDG B777 in either P3Dv3 or v4 (all the other GF modules are working fine).
The GF-46 works as programmed with PMDG's B747-400 in both P3D versions and so it does with PMDG's B737 in P3Dv3 (not yet released for v4).
I only use GIT for my PMDG add ons.
I wonder if anybody else has encountered this issue, as I am a bit puzzled by it and at a loss as to how to diagnose it.
Thx!
Roberto
  • Hi Roberto,
    Try clicking the Red X on the GF-46 tab when the 777 is loaded up so that it wipes the config for it. Then quit and reload GIT and it should be reconfigured to default settings. I may also be worth checking it is actually enabled in GIT.
  • Hi Steve:
    Did all that but, unfortunately, with the same results.
    Roberto
  • That's weird. I will have to try it on my test rig later on today and come back to you.
  • Hello Steve:
    Rebooted the computer after doing the changes you suggested and, now, all is well!
    Thanks!
    Roberto
