Problem with SECM and the Interface Tool
Hello und Greetings from Germany,
first of all, i hope you can understand my Problem. English is not my Motherlanguage but i hope you can understand where my Problem is.
I have watched the Tutorial Video from Rob and i want to pratictise with the GoFlight Interface Tool.
My Hardware from GoFlight ( GF-MCP, SECM, RP48, 2X GF46, 3x GF166A VRP )
I tried to config the Standart Beech Baron G1000 from P3Dv4.
Wenn i use the Avionics Master the Detective gives me 2 Events :
0000000127 Event: 066293 Event Data: 000001 Event Name: TOGGLE_AVIONICS_MASTER
0000000128 Event: 066379 Event Data: 000001 Event Name: TOGGLE_NAV_LIGHTS
Why 2 Events on this Switch. Then i create a New Bespoke Event and i put only 1 Event in. Event: 066293 Event Data: 000001 Event Name: TOGGLE_AVIONICS_MASTER
The i put the new Event on the Switch but it shows me again the two events from the Beginning ?
Where is my mistake ?
Greetings from Berlin
Christian
Christian
I'm not sure what you mean by "The i put the new Event on the Switch but it shows me again the two events from the Beginning ?"
Do the AVIONICS come on when its selected or Tested in Detective?
If both events activate, then that is how the aircraft is built with FSX.
Wenn ich den Schalter am SECM Avionics Master auf ON it gives me every Time 2 Events ( See Picture )
Why 2 Events i have only programm 1 Event to this switch
http://www.bilder-upload.eu/show.php?file=bdf54e-1500143195.jpg
No of course not. This is my problem.
Have you double checked nothing else is configured to "drive" the SECM such as FSUIPC, GFConfig, Linda etc - its the usual cause of multiple events firing as each piece of software responds to the switch action and sends the event you have configured.
1: Event: 066293 Event Data: 000001 Event Name: TOGGLE_AVIONICS_MASTER
2: Event: 066379 Event Data: 000001 Event Name: TOGGLE_NAV_LIGHTS
When i test the Bespoke Events in the Detective, then everything is fine. When i use the Avionics Hardware Swich at the SECM the Nav Lights toggle two and when i toggle the Nav Lights its toggle the Avionics Master Switch.
There is nothing else I can advise.
