BLANK display feature improvement request?
I am trying to take advantage of the new BLANK display feature introduced in 1.3 to turn OFF the displays not in use at different phases of flight as per a Boeing 737.
i.e. for the VERTICAL DISPLAY.
The VERTICAL DISPLAY should be OFF/BLANK any given time that VS mode is not active.
At the present time the BLANK light option allows to validate against the dataref value you use for displaying data on the display. But this is not usefull because the dataref is the data you shown on the display when the display should be active but this dataref does not tell whether the display should be working or not.
Is it possible to add an extra field/dataref option for the BLANK field validate against to validate if the DISPLAY should be ON/OFF?
The dataref that should be shown on the Veritcal Display data is sim/cockpit2/autopilot/vvi_dial_fpm but the dataref the BLANK feature should check against to for deciding to blank the display or not is laminar/B738/autopilot/vs_press. This extra field may be a dataref or a bespoke for more complex verifications like IAS display that goes ON or OFF under more AP mode options
Hope i was able to explain the issue under the current feature implementation.
Maybe the option is there but i missunderstood how to configure?
Alternatively, create a Start event that runs continuously that reads a dataref and sets a Bespoke Variable to the display visibility.
Test if display is on (check value of a dataref)
If display is on set Bespoke Var to the value that needs displaying, otherwise set it to -9999999.
In the config, BLANK if the value is -9999999, Light/Disp Data is the Bespoke Var.
The relevant datarefs are ..
1-sim/comm/AP/vviUP and 1-sim/comm/AP/vviDN
sim/cockpit2/autopilot/vvi_status. Tells you when the system is active. Value is 0 when off and 2 when on. So when this dataref is 2, I want the "Display_VS" on
757Avionics/ap/vs_act. This is the dataref that feeds the Light/Display Data for the "Display_VS". I have this set to blank when equal to 0.
My "Rotary_VS" Clockwise and AntiClockwise control 1-sim/comm/AP/vviUP & 1-sim/comm/AP/vviDN respectively.
As the OP stated, when you reach your altitude, although the vvi_status switches to 0, the vs_act which feeds the display stays where you set it and the display does not blank.
I just can't decode the above post to figure out where to put my bespoke event so that this happens.
Thanks for any help,
p
if sim/cockpit2/autopilot/vvi_status = 0 Next Else NextSkip
757Avionics/ap/vs_act = 0
This bespoke event works and does what I need to do. But what do I assign it to?
p
For anyone else out there this is my start bespoke event..
:top
Sleep 20
Goto top
p
