Settings being over-written
Can people report back if the following steps cause their setting file to be over-written and whther its all devices or just specific devices that loose their settings:
1 - Launch FSX
2 - Launch Interface Tool
3 - Load plane.
4 - Once in the Virtual Cockpit, quit FSX.
6 - Close Interface Tool.
then try this:
1 - Launch FSX
3 - Load plane.
4 - Once in the Virtual Cockpit, go and fly for a while and then quit FSX.
This has been reported as a bug, and I'm struggling to recreate it and need some more feedback.
Many thanks
This discussion has been closed.
Hi Steve
Tried both steps above using Prepar3D and 2.0.241.0 and the settings file remained intact both times. However, on starting Prepar3D the 2nd time, it crashed before reaching the virtual cockpit and the error below was reported in Event Viewer (btw starting Prepar3D a 3rd time worked fine).
Log Name: Application
\Lockheed Martin\Prepar3D\Prepar3D.exe
Source: Application Error
Date: 16/02/2013 01:02:58
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: Study-PC
Description:
Faulting application name: Prepar3D.exe, version: 1.4.4747.0, time stamp: 0x50253a53
Faulting module name: GoFlight Interface Module.dll_unloaded, version: 0.0.0.0, time stamp: 0x5113fa45
Exception code: 0xc0000005
Fault offset: 0x52251b16
Faulting process id: 0x550
Faulting application start time: 0x01ce0be0f2fc48c3
Faulting application path:
Faulting module path: GoFlight Interface Module.dll
Report Id: 99d4bddf-77d4-11e2-9d5d-005056c00008
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-02-16T01:02:58.000000000Z" />
<EventRecordID>15275</EventRecordID>
<Channel>Application</Channel>
<Computer>Study-PC</Computer>
<Security />
</System>
<EventData>
<Data>Prepar3D.exe</Data>
<Data>1.4.4747.0</Data>
<Data>50253a53</Data>
<Data>GoFlight Interface Module.dll_unloaded</Data>
<Data>0.0.0.0</Data>
<Data>5113fa45</Data>
<Data>c0000005</Data>
<Data>52251b16</Data>
<Data>550</Data>
<Data>01ce0be0f2fc48c3</Data>
<Data>D:\Lockheed Martin\Prepar3D\Prepar3D.exe</Data>
<Data>GoFlight Interface Module.dll</Data>
<Data>99d4bddf-77d4-11e2-9d5d-005056c00008</Data>
</EventData>
</Event>
Thanks for that. I'll add your error to the bug list.
Issue identifed and resoloved in version 2.0.300.0
Topic closed.
