IFLY 747 programming
I have understoof now how to program for PMDG.
I am trying to program for IFLY, and, as I do not have the SDK, I cannot find out.
Could you help me for 2 exemples, and then I'll try to continue by myself : Landing lights and seat belts.
Thank's a lot in advance
Yves
Yves
KEY_COMMAND_IFLY744_GENERAL_LANDING_LIGHT_ON
KEY_COMMAND_IFLY744_GENERAL_LANDING_LIGHT_OFF
Assign to the ON and OFF Switch Events of a switch as necessary.
For a button use the toggling event: KEY_COMMAND_IFLY744_GENERAL_LANDING_LIGHT
The Button/Switch Action should be NOTHING.
For the Light use LIGHT_LANDING, with an Action of ON and a value of 1.
For the seatbelts search for "seat" and you will find:
KEY_COMMAND_IFLY744_GENERAL_SEATBELT_DEC
KEY_COMMAND_IFLY744_GENERAL_SEATBELT_INC
KEY_COMMAND_IFLY744_GENERAL_SEATBELT_OFF
KEY_COMMAND_IFLY744_GENERAL_SEATBELT_AUTO
KEY_COMMAND_IFLY744_GENERAL_SEATBELT_ON
The INC and DEC commands are best suited to a rotary although you could assign DEC to the ON event of a button and the INC to another buttons ON event
For the Light use Seat_Belt_Switch_Status with an Action of ON_GREATER_THAN and a Value of 0.
Yves
Yhank's
Yves
Yves
Its not the sane as the PMDG aircraft where you only set one event, you have to set two events sometimes (ON and OFF, CLOCKWISE and ANTI-CLOCKWISE)
If I understand, I must program 2 events for 1 button? How do I manage this.
I'm sorry but Y do not understand!
Yves
Don't assign OFF events to GoFlight push buttons because once you release the button, the OFF event will fire. Do use OFF events for GoFlight switches.
