Problem with PMDG Interface higher than 1.087
Hallo the newer Version of PMDG above 1.087 the middle Lamp shows yellow
light. In vers. 1.087 all green. I do´t know what it is.
Here a copy of the Log-file Vers. 1250:
20:23:06 GoFlight Connection Starting.....
20:23:06 SimConnect Connection Starting.....
20:23:08 GoFlight Connection Started
20:23:46 SimConnect Message Processing Started
20:23:46 SimConnect Connection Started
20:23:46 Aircraft Connection Starting.....
20:23:48 Aircraft Connection Started
20:23:48 Synchronising Switches & Selectors .....
20:23:48 Synchronising Switches & Selectors: Waiting for Simconnect .....
20:24:03 SimConnect: Event Received: Start
20:24:04 SimConnect: Event Received: Aircraft Type Changed
20:24:04 SimConnect: Event Received: SIM, 0
20:24:04 SimConnect Message Processing Finished
20:24:04 GoFlight Connection Starting.....
20:24:04 SimConnect Connection Starting.....
20:24:05 GoFlight Connection Started
20:24:05 SimConnect Message Processing Started
20:24:06 SimConnect Connection Started
20:24:06 Aircraft Connection Starting.....
20:24:06 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:24:06 SimConnect: Event Received: SIM, 0
20:24:06 SimConnect: Event Received: PAUSE, 1
20:28:34 PMDG SDK option is OK in FSX
20:28:34 Prepar3D registry AppPath entry not found
20:28:35 Aircraft Connection Started
20:28:37 SimConnect: Event Received: Aircraft Type Changed
20:28:37 SimConnect Message Processing Finished
20:28:37 GoFlight Connection Starting.....
20:28:38 SimConnect Connection Starting.....
20:28:40 SimConnect Message Processing Started
20:28:40 GoFlight Connection Started
20:28:40 SimConnect Connection Started
20:28:40 Aircraft Connection Starting.....
20:28:41 Aircraft Connection Started
20:28:41 SimConnect: Event Received: Start
20:28:41 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
20:28:41 SimConnect: Event Received: SIM, 0
20:28:41 SimConnect: Event Received: PAUSE, 0
20:29:54 SimConnect: Event Received: SIMSTART, 0
20:29:54 SimConnect: Event Received: SIM, 1
20:29:58 SimConnect: Exception Received:  UNRECOGNIZED_ID
20:30:01 Synchronising Switches & Selectors Complete
  • edited November -1
    Its this:
    If everything is working OK, you can ignore it.
    Thanks for Info Steve.
    Mfg
    Klaus
