Displays
Thanks for fixing that issue so I could get that one event working. I'm trying to figure out how to get the MCP displays to work.
For instance:
Event: 069656 Event Data: 000035 Event Name:
That is the input for rotating the heading knob. The Event Data is the actual heading the bug result is after the knob is rotated. Is there anyway to turn that data result into something the MCP can use to populate on the heading display? The same can be said for the Altittude and speed windows.
Thanks for any input you can think up.
Regards,
Brian
  • Hi Brian,
    You need to use Detective and monitor what Dataref changes to reflect the heading value and then use that Dataref for the display.
