P3Dv4
Ever since I upgraded to P3Dv4, my MCP PRO has not worked. I have downloaded the correct PollyPot software but still no joy. This is want I get in the GIT Interface Tool log: PLEASE ADVISE??
08:14:10 FSUIPC: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:8385
08:14:10 Aircraft Connection Started
08:14:10 Simconnect Version: 3.4.0.0
08:14:10 Aircraft FullName: Generic
08:14:10 Synchronising Switches & Selectors .....
08:14:10 Synchronising Switches & Selectors: Waiting for SimConnect .....
08:14:50 SimConnect: Event Received: Start
08:14:50 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
08:14:50 SimConnect: Event Received: SIM, 0
08:14:50 SimConnect: Event Received: PAUSE, 0
08:14:50 SimConnect: Exception Received: OUT_OF_BOUNDS
08:18:00 PMDG SDK option is OK in Prepar3D v4
08:18:00 SimConnect: Event Received: Aircraft Type Changed
08:18:00 SimConnect Message Processing Finished
08:18:00 GoFlight Connection Starting.....
08:18:00 SimConnect Connection Starting.....
08:18:01 SimConnect Message Processing Started
08:18:01 GoFlight Connection Started
08:18:02 SimConnect Connection Started
08:18:02 Aircraft Connection Starting.....
08:18:03 Aircraft Connection Started
08:18:03 Simconnect Version: 3.4.0.0
08:18:03 Aircraft FullName: PMDG 737-800NGX WL
08:18:08 SimConnect: Event Received: Start
08:18:09 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
08:18:09 SimConnect: Event Received: SIM, 0
08:18:09 SimConnect: Event Received: PAUSE, 0
08:18:09 SimConnect: Exception Received: ILLEGAL_OPERATION
08:23:04 SimConnect: Event Received: SIMSTART, 0
08:23:04 SimConnect: Event Received: SIM, 1
08:23:34 SimConnect: Exception Received: UNRECOGNIZED_ID
08:23:35 Synchronising Switches & Selectors Complete
08:23:43 SimConnect: Event Received: SIMSTOP, 0
08:23:43 SimConnect: Event Received: SIM, 0
08:24:06 SimConnect: Event Received: SIMSTART, 0
08:24:06 SimConnect: Event Received: SIM, 1
08:27:39 SimConnect Message Processing Finished
08:27:39 GoFlight Connection Starting.....
08:27:39 SimConnect Connection Starting.....
08:27:40 GoFlight Connection Started
08:27:40 SimConnect Message Processing Started
08:27:40 SimConnect Connection Started
08:27:40 Aircraft Connection Starting.....
08:27:40 PMDG SDK option is OK in Prepar3D v4
08:27:40 SimConnect: Event Received: Aircraft Type Changed
08:27:40 SimConnect: Event Received: SIM, 1
08:27:40 SimConnect: Event Received: PAUSE, 0
08:27:40 SimConnect Message Processing Finished
08:27:40 GoFlight Connection Starting.....
08:27:41 SimConnect Connection Starting.....
08:27:42 SimConnect Message Processing Started
08:27:42 GoFlight Connection Started
08:27:42 SimConnect Connection Started
08:27:42 Aircraft Connection Starting.....
08:27:42 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
08:27:42 SimConnect: Event Received: SIM, 1
08:27:42 SimConnect: Event Received: PAUSE, 0
08:27:43 Aircraft Connection Started
08:27:43 Simconnect Version: 3.4.0.0
08:27:43 Aircraft FullName: PMDG 737-800NGX WL
08:27:43 Synchronising Switches & Selectors .....
08:27:43 SimConnect: Exception Received: UNRECOGNIZED_ID
08:27:44 SimConnect: Exception Received: UNRECOGNIZED_ID
08:27:47 Synchronising Switches & Selectors Complete
Also are you running the very latest P3D and NGX versions?
