follow up on lua script for pmdg 777
Ok, so tried to follow example from ngx to create a script that will turn on both ac packs in the pmdg 777. Basically I created this:
if (getkvar("DATA_OH_AIR_SWITCH_L_PACK") == 0) then
       sendevt("EVT_OH_AIRCOND_PACK_SWITCH_L", MOUSE_LEFTSINGLE)
end
when I try to run it from the lua console, I get the following error:
Error: ...s\GoFlight Interface Tool\LUA\PMDG 777\eric_airpacks.lua:2: unexpected symbol near '<\160>'
Can you please tell me what I did wrong?
  • Hi Bill,
    I think the editor you are using has saved the file in HTML format. Try using notepad or notepad++ as it needs to be a text file.
  • will do, I was just using what automatically opened via the lua console. I'm using windows 10 if that matters
    thanks
  • hi again. I made sure that I was using Notepad as the lua editor and I'm still getting the issue. Can you test that event? Assuming you have PMDG 777. Maybe my code is wrong?
  • here is the complete script for trying to turn on the left pack:
    end
    sleep(75)
    setbvar("Bespoke Var 0", getkvar("DATA_OH_AIR_SWITCH_L_PACK"))
    error code:
    thanks for your help
  • ok, found the issue. apparently when I copied your NGX example, it had some extra spaces in the code (specifically after "if"
    Deleted the spaces and seems to work
  • I suspect copying and pasting into an editor that understands html, is also copying the hidden html into the file as well. The hidden spaces was probably html.
