MJC Q400 x64 Profile Beta
Beta version of Q400
Please post any questions or suggestions here and I will try my best to implement them within reason.
I still need to implement the EFIS again but wanted to get something out so you can use the MCPPro with GIT again.
There are a lot of overhead buttons and switches in the profile already. If you are building a custom profile I will not change the names of bespoke events and you can use them in your custom profile. All you will need to do to get the new bespoke events I create is to open detective and click the button to delete all bespoke events, then click the button to import the new mjcq400.xml file. This will keep your assignments but give you access to new bespokes as I create them.
I'll try to update the changelog file as I make progress on it.
Steve McNitt
Any more progress on this? I've been trying to figure out stuff on my own, but not having much success..i.e. Found how to turn on Autofeather, but can't turn it off.
For instance I tried EFISdata_->EFCP_controls2.button_WXTERR_pressed is pushing the FUEL SYS button instead of the FO WX/Terr button. EFISdata_->EFCP_controls2.button_FORMAT_pressed is pushing the DOORS SYS button instead of the FO Format button
Never tried the fake Lvars til now because I was too lazy and didn't want to redo the whole profile, but now it's the only way forward.
I suspect not many people used the fake lvars as it wasn't compatible to my original profile so these might have not got fully tested
What are "fake Lvars"?
The two are not compatible and cannot be mixed together at all.
Mouse events still work with both versions except I still haven't mapped them all out yet. My new profile is using a mix of mouse events and fake LVARS. I prefer the mouse events for momentary push buttons or toggles as there is no need to make an on event and off event. Fake LVARS are good when you need to read data or have to set something specific.
The fake LVARS also don't require a monsterous start event anymore either so it seems a bit more stable but you may fine tune your delays on the MCPPro to get things more responsive as the Q pumps out data every frame I believe.
I decided to do a flight in another aircraft tonight (PMDG 777) to see if the problem would materialize with a different aircraft, but so far (just reaching cruise) I have not experienced the same issue.
I haven't tried FS2crew yet but I'm still having issues with GFIT, albeit different ones this time. Attempt 1 resulted in all dials, knobs etc inoperative even on the ground. Attempt 2 resulted in the lights from left to right red yellow flashing red and GFIT froze up. I've attached a text file to this post with both logs.
Not sure on 2nd attempt.
Try starting GIT after you load up the Q400 and also maybe try running as admin if you don't already.
It would be appreciated if you could give me a couple of suggestions as to how to make it work.
Thanks.
Martin
