Engravity CDU PMDG Interface- compatible with P3DV4.1?
Hello,
is the new Version 2.0 of this Interface compatible with P3D V4.1?
Cannot connect to the PMDG 747QOTSII. First CDU screen shows up
but not any further changes. No input on unit possible.
Everything is fine with FSX.
Thanks for info.
Gerd
  • Problem has been fixed. Used FSX Version.
    Shame...
  • Thanks for this info.
    I have had a few people struggle with GIT connecting to P3D v4 as well, and the answer seems to be that P3Dv4 is not fully compatible with its previous SDK's. I knew the 1.x dll did not work with v4, but this now suggests that the v2 and v3 dll's have compatibility problems. They certainly worked with the hotfix version of P3Dv4 but the subsequent releases have clearly broken compatibility.
    I will have to produce a v4 dll version specifically for P3Dv4 in the new year.
