46'S still keeping locking up even with SLEEP
This problem seems to be specific to the 46's, the 48's work well.
I've tried many different sleep values and "Run event in background" but my 46's dial action always ends up locking up the 46 so it becomes completely none functional until a "reboot" ... these seems more like a buffering problem at the driver level?
Any other suggestions?
The GoFlight SDK only offers the option to read and write to the device, GIT has very little control. The only thing you can change is the sliders in the Settings tab which delay writing to the GF166 and GF46 devices to help avoid lockups. Also like the GF166, separate out onto different hubs sometimes helps.
Is it happening in all versions of GIT with all aircraft?
Is there anything in the USB device descriptions that might provide a clue as to what version of firmware they have? For reference my 166s are relatively new (purchased last month) and they have NOT locked up. One of my 46's is also relatively new (last month) and my other 46's is older (year or so) ... both 46's HAVE locked up.
I can't say if this is aircraft specific, I've really only started doing "custom" configurations of the 46's recently using the JF PA28R for XP11. I have the JF PA28R for P3D V4 also, so I can test it out in that environment.
I tried several values for the write delay this evening and even other settings to see if there was any change, unfortunately nothing seems to work, the 46 would lock up on any rapid forward and then backward rotary movement. If I rotate slowly, everything works fine.
The most annoying part of this problem is that it requires a reboot to unlock the 46.
Cheers Rob.
