no information on the display of engravity version 1.04
The issue is that I get no information on the display of the Engravity. The window of the driver show all green. If it is connecting you see te page of the CDU. if I push the buttons you can see the information virtual on the computerscreen, but not on the Engravity-screen.
I installed the newest version of PMDG 737NG and prepar3d v4 and also the newest CP210 driver.
The older prepar3d v3 is completley uninstalled
please help me
The Log file
1:59:58 MainViewModel: CDU0 Starting.....
1:59:58 SimConnectWrapper: SimConnect Message Processing Started
1:59:58 LockheedMartin.Prepar3D.SimConnect.SimConnect: Start Event Received!
1:59:58 Aircraft: Prepar3D v3 ini file not found
2:00:01 CDU0: Exception of type 'A.+CommErrorException' was thrown.
2:00:02 CDU0: Status Changed:
2:00:02 CDU0: Message Received: 2
2:00:13 MainViewModel: Event Received: Aircraft Type Changed
2:00:13 LockheedMartin.Prepar3D.SimConnect.SimConnect: SIM, 1
2:00:13 LockheedMartin.Prepar3D.SimConnect.SimConnect: PAUSE, 0
2:00:13 AircraftInterfaceNGX: Left CDU Data Received
2:00:56 CDU0: Key Pressed: $PCDUKEY,COMM42*73
2:00:56 CDU0: Message Received: NEXTPAGE
2:00:58 CDU0: Key Pressed: $PCDUKEY,COMM41*70
2:00:58 CDU0: Message Received: PREVPAGE
2:01:00 CDU0: Key Pressed: $PCDUKEY,COMM42*73
2:01:00 CDU0: Message Received: NEXTPAGE
2:01:00 CDU0: Key Pressed: $PCDUKEY,COMM41*70
2:01:00 CDU0: Message Received: PREVPAGE
2:01:06 CDU0: Key Pressed: $PCDUKEY,E*3C
2:01:06 CDU0: Message Received: E
2:01:07 CDU0: Key Pressed: $PCDUKEY,H*31
2:01:07 CDU0: Message Received: H
2:01:09 CDU0: Key Pressed: $PCDUKEY,A*38
2:01:09 CDU0: Message Received: A
2:01:11 CDU0: Key Pressed: $PCDUKEY,M*34
2:01:11 CDU0: Message Received: M
2:01:15 CDU0: Key Pressed: $PCDUKEY,LS1*57
2:01:15 CDU0: Message Received: LS1
2:01:23 CDU0: Key Pressed: $PCDUKEY,E*3C
2:01:23 CDU0: Message Received: E
2:01:26 CDU0: Key Pressed: $PCDUKEY,G*3E
2:01:26 CDU0: Message Received: G
2:01:27 CDU0: Key Pressed: $PCDUKEY,L*35
2:01:27 CDU0: Message Received: L
2:01:28 CDU0: Key Pressed: $PCDUKEY,L*35
2:01:28 CDU0: Message Received: L
2:01:30 CDU0: Key Pressed: $PCDUKEY,RS1*49
2:01:30 CDU0: Message Received: RS1
