Failed to load configuration data when import xml file from other aircraft setting
Hi All,
Have setup my GF45 and P8 for default 737.
When i try to import the saved XML file to use settings for the 737-800 ZIBO, i get the error "Failed to Load Configuration Data for device GFDEVHWTYPE_GF45.
By the way. In the status screen with ZIBO loaded, it shows Aircraft GENERIC and 738. Maybe it will be seen as the same aircraft ??
Questions:
- Is the 738 ZIBO supported for GIT?
- Can i reuse the setting from default 738 for the 738 ZIBO?
- If so what do i need to do to reuse the settings? Or do I need a complete new config.
Thanks!
Andre
Questions:
Thanks!
Andre
When i load the default 738, all setting for the GF45 are gone. When i try to import my saved file i get the same error "Failed to Load Configuration Data for device GFDEVHWTYPE_GF45"
Sorry, wrong bespoke events where loaded. My fault!
Import and setup is working for 738 ZIBO.
Case closed ;-)
