pmdg ngx - help setting up lua bespoke event for indicator lights on gf panels
Hi, trying to create lua events for PMDG ngx. I'm following the anti ice example found in the user guide here. I successfully mapped the function to a button on a P8 module and the light turns on when I activate the antiice. However, I can't seem to get it to turn off. I'm using the light data on, value of 1. I thought when I switch to the Off side, I would just but a light data of OFF and value of 0 but discovered there is only one setting for both directions of the switch.
Any help?
Bill
  • Hi Bill,
    Did you create an Lua script for the OFF event. If you see the anti-ice code there is another script for the OFF event.
