GIT STOP WORKING WITH ZIBO
Hello everyone. Since yesterday I started having problems with my MCP-PRO with zibo. From what I see, it does not read the dataref.txt. And the GIT does not get it. With Ixeg everything works perfect, and I do not add any new plugin. I already deleted all the plugins, and I did all the tests, but it still does not work.
I load the GIT first and get one green light. Then I load X-Plane and all three lights go green. I load an aircraft Zibo 737 and the cogwheels appear and begin to rotate but NOTHING ELSE EVER HAPPENS. The MCP Pro tab remains greyed out and the only button that is active is "Restart". If I press that I simply get three reds and the repeating message "GIP Pipe Connection Failed!".
I tried to import the new David Williams file, through the IMPORT WIZARD button, but it still does not work. When I start importing the new files, it takes many minutes and the git stops working. The files are not imported.
Nothing works. Also start the GIT as administrator and xplane as well, but it does not work either. I also created a new GIT folder in the documents folder, but it did not work either.
So I see the git if it reads the files commands.txt - obj datarefs - acf datarefs - dre datarefs - obj commands. But it does not read the datarefs.txt file. A red cross appears next to the datarefs.txt file. And in the aforementioned files, they appear with a green tilde.
Someone could help me?
  • Duplicate post. Closing this as I have answered you on the other thread.
This discussion has been closed.
