Zibo B737-800 Compatability
Testing the config file with the latest Zibo version (3.25i) and have found an issue with the aircraft power settings in GIT. I use the power_on_buses dataref to indicate power to the aircraft in the Aircraft Power dialog. This dataref has been commented out in the lua and no longer used.
If you are using the AV_ENABLED mode for your equipment, go to the Aircraft Power dialog (button on status page) and change the Power Data dataref from laminar/B738/electric/power_on_buses to laminar/B738/electric/batbus_status. Don't forget to export so as to update the documents directory.
